TPI idles erratically,HELP
Old Dec 1, 2001 | 08:31 AM
rallysport's Avatar
when the car is warm it will idle about 1200 rpm then it will go down to about 600rpm. this wil happenthe whole time I drive it. I have looked for vacuum leaks and haven't found any yet. That was my first thought. Anyone have any other ideas? thanks
Old Dec 1, 2001 | 12:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Maybe need to clean the IAC passages in the TB (whole TB as well) and possiblibly look at the IAc and or control parameters.
Old Dec 3, 2001 | 12:34 PM
rallysport's Avatar
top
Old Dec 3, 2001 | 12:37 PM
tpi_roc's Avatar
Just for good measure set your TPS too.
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 3, 2001 | 04:42 PM
rondubbs's Avatar
o2 sensor
Old Dec 3, 2001 | 05:37 PM
David Petersen's Avatar
Ditto to all the above, and jsut a thought..this may sound funny but if you are getting a bad MAF senser code and you replace the sensor and it keeps doing the same thing the burnoff relay is bad. My car was doing the exact same thing so I replaced the MAF which was the code up but the burnoff relay went south and the MAF was getting false readings. If you arn't getting the code this probably isn't your porblem.
Wade787b
Sep 29, 2015 01:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
