Car Blowing UP????
Old Dec 1, 2001 | 02:20 PM
CloudZStrife's Avatar
Car Blowing UP????
Well I just got a new 305 complete Block......I have a very serious leak with my 700r4 (stock with 116000),....When I tried to start it the other day, it cranked then I heard grinding metal, when i got out of the car It smelt like somethin had spun or had burned! Since I did'nt replace the Tranny and did'nt put in any fluid to it do you guys think it mighta been the tranny, I'm gonna be replacing the unit with an 700r4 Raptor but is this what happens when the tranny is run on low Fluid?
87 IROC-Z, 3.23 posi, new 305 TPI, and soon to get new trans and world torquer 305 heads
Old Dec 1, 2001 | 04:52 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Hey Cloud, just how low on fluid was the tranny? My dumb a** started up an engine w/o adding tranny fluid one time, it was about 5 qts low. No grinding or squealing, but there was smoke coming out the tranny dipstick hole and it wouldn't even shift out of park. Where'd you get the 305 from? Not trying to scare ya, but that just don't sound good.
91 Z28
Come see The Vicious...
Old Dec 1, 2001 | 04:57 PM
WEll I got the 305 from this speed shop, it's an AC Delco Remanufactured unit...Umm It's brand new no miles on it, but my tranny had a leak when i brought it to the shop before I had the engine done, I did'nt start it for long maybe a couple of seconds I was thinking maybe my Tranny seized up, because when i smelt the burning it smelt like burnt Rubber or burnt plastic and the engine cut out,.I have'nt started it since, but there's is a pool of tranny fluid in my garage. red fluid's tranny right
Old Dec 1, 2001 | 05:08 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, tranny fluid is red. Just how low is it? Mine wasn't even on the dipstick, took about 3 qts to even get it to read. Did the engine ever start, or did it just crank? (There's oil in it, right?) It could be something electrical hooked up wrong that melted, or maybe your starter grinding. Just a few ideas.
You're probably afraid to try, but does it do anything now? Another quick thing to check, get a breaker bar and a 5/8 socket and try turning the engine by hand at the harmonic balancer bolt. It should be difficult but you ought to be able to get it to move. And take a look at the wires coming off your starter, see if any of them are baked.
91 Z28
Old Dec 1, 2001 | 05:19 PM
Alright well the car does turn over and starts but when i starting it this time, it ran for about 6 seconds then I heard a grinding definatly from the tranny this time and there was lil bit of smoke coming from the rear of the tranny between the driveshaft and the tranny....it was kind of a white smoke, but not alot just a little hint to me i guess.... Oh well time for new tranny time
Old Dec 1, 2001 | 05:22 PM
Hey your pretty Hot, I was just lookin at your site, hum I thought only guys were interested in cars, makes me believe there's hope out there to find a women that digs cars, wow i guess ya learn somethin new everyday. thanx for the help
Old Dec 1, 2001 | 05:42 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Hell yeah shes hot.
Old Dec 1, 2001 | 05:47 PM
Mult 68 stop you goof.. I was just bein nice lol
Old Dec 1, 2001 | 05:48 PM
oh yea there's a full pan of oil in the engine
Old Dec 1, 2001 | 06:02 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
uhhh ... thanks guys. Yes, f-body fanatic, and ffvii nut as well. But madly in love with Seph, sorry Cloud.
91 Z28
[This message has been edited by ViciousZ (edited December 01, 2001).]
Old Dec 1, 2001 | 09:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well, if the transmission worked perfectly fine before the new engine was stabbed, it is unlikely that it destroyed itself while having the engine swapped. While starting the engine with the trans low on fluid is not a good idea, it really shouldn't toast the entire box if it is just low a few quarts. Now, if it was really low on fluid and you started trying to drive it a bunch, that tends to do some damage in a hurry.....
It is really hard to say without being there, but it sounds like you may have a problem with the flywheel vs. torque converter mating, or the torque converter vs. front pump of the trans mating. I would take off the inspection cover and make sure the converter is completely seated into the front pump of the trans as well as check on the mounting of the flywheel to the torque converter for any problems. Loud grinding with the trans in park (I am assuming you had the trans in park) and the engine idling just doesn't sound right to me......
And the fluid on the ground just doesn't jive to me either, unless the torque converter isn't fully seated into the front pump. In that case, that would be the source of all of your problems. But you really need to find exactly where the fluid is coming from. Did you have the cooler lines off the radiator during the engine swap? If so, have they been reinstalled?
Well, there's some ideas for ya......
lol Vicious
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Dec 1, 2001 | 10:13 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Just thought I'd add a) The above sounded about right, but Aeris is the hottest....
Old Dec 2, 2001 | 04:14 PM
heheheh hey thanx I'll check that in a bit I'm prolly getting a new Converter and Trans in the next week or so, but man I really wanted to salvage the transmission. Oh well If I had more time and the right equipment I'd remove it and find out what the Hells goin on. Oh Well Bout time for a new Tranny anyhow...
Old Dec 2, 2001 | 04:18 PM
Oh yea.... that's awesome that's like my favorite game too oh well....lol I did'nt get it at first, oops....It's my nickname at work and not really cuz my heads up in the Clouds but oh well, What would you guys say the average age of people On this board is , I'm 19, bought the Iroc when I was 16,
Old Dec 2, 2001 | 04:22 PM
IROCZ383TRS's Avatar
this might be a little bit of work, but have u pulled off the tranny pan to see what kinda damage u have done to the tranny????
Old Dec 2, 2001 | 04:23 PM
Also I remember they put on a new Flywheel, because my old one grinded when starting sometimes. But I have'nt had that Problem with the new engine, I'll check the Converter Tonight see if it's flush against the tranny, watch me take off the inspection cover and oil go all in face,, hahahahahah oh man what trip, lol , Hey what's wrong with Cloud anyhow? He's was like the best charecter? plus he had the big fat Buster Sword lol
Old Dec 2, 2001 | 11:47 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Cloud, did you ever take the torque converter off the tranny?
And Matt, if the tc wasn't seated in the pump how could it bolt to the flywheel/flexplate and still have the bellhousing mate up to the back of the block correctly? I can't figure it out but I know it can be done because I've seen a guy ruin his tranny that way. Just curious because I'm always paranoid about not getting the tc on all the way.
Continuing the non-tech:
Cloud was kinda a goody-goody. Besides, Sephiroth's sword was l-o-n-g-e-rrrr.
Azure, you're wrong. Sephiroth was the hottest by far. C'mon ladies, back me up here. Ladies??? (and the 3 other girls on the bb are thinking huh? what? Who?)
In answer to your question, yeah, I think most of the people on this board are about your age. Seems like a lot of highschool and college guys around here.
91 Z28
[This message has been edited by ViciousZ (edited December 02, 2001).]
Old Dec 3, 2001 | 12:49 PM
That's cool, I was told it's not the meat it's the motion...lol. any how no I have'nt takin the Converter Off, nor have i even played with the tranny, but I'm gonna check because It seems I have some kind of little bit of oil leak, from the tranny dripping down, but I'm gonna pull the cover off and check it out and get a flash light and check around.
Old Dec 3, 2001 | 05:29 PM
Matt87GTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ViciousZ:
And Matt, if the tc wasn't seated in the pump how could it bolt to the flywheel/flexplate and still have the bellhousing mate up to the back of the block correctly?</font>
Well, I think you answered your own question. The way that the TC is able to be bolted to the flywheel even though it is not fully seated into the front pump of the transmission, is by destroying either the front pump, or the drive dogs of the TC. Basically the TC or the front pump get crushed at some point during the install of the engine onto the transmission (or vice versa). If you have stabbed enough engines, this will likely not happen to you because it will be obvious that the engine isn't going in right, plus the TC won't free-spin behind the flywheel when the engine is bolted to the trans but the TC bolts haven't been installed.
<font face="Verdana, Arial" size="2">Continuing the non-tech:
</font>
Ummmmm...... WTF, over?
1987 GTA L98 MD8
My GTA
Old Dec 3, 2001 | 08:38 PM
lol oh it's kinda an inside joke... but that's a good point I'm gonna try looking for that tommorrow and post anything I've found, I just ordered a new transmission a basically new stock one with a vette servo, mega valve, and 3-4 kickdown, But I'm still hoping to salvage the old one and get some money out of it..
Old Dec 3, 2001 | 11:07 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Originally posted by Cloud:
<font face="Verdana, Arial" size="2">I was told it's not the meat it's the motion...lol.</font>
That's not what I meant. Somebody's got a dirty mind...
Matt, thanks about the tc, exactly what I needed to know. And I've only stabbed 4 engines, 3 auto, so I'm still paranoid. Guess I know how to check it now.
Originally posted by Matt87GTA:
<font face="Verdana, Arial" size="2">Ummmmm...... WTF, over?</font>
LOL, yeah, I guess it is a little of an inside joke. I'll explain later.
91 Z28
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
maroe624
Apr 16, 2017 08:29 AM
jackhammer
Aug 15, 2015 10:04 PM
