bad sputtering / jerking
Old Nov 21, 2005 | 05:46 PM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
my car is a 1991 firebird, v6 3.1 automatic, this problem started about a month ago and has progressivly gotten worse. latly when i start her up the idle is rough, but the rpm stay steady, but when i hit the road thats when i gets bad, starts jerking and sputtering pretty bad, again the rpm is staying steady. ive also pulled a code, 32, the erg has been recently replaced, so my next guess would be a vacume leak, i would hope thats the problem, just wonding what everyone else thinks. thank for the help in advance
Old Nov 21, 2005 | 08:18 PM
Vader's Avatar
The symptoms you describe could be caused by weak ignition or a lean mixture condition. Ignition would include spark plugs, wires, distributor cap, rotor, and coil(s).
Lean mixture can be due to vacuum leaks, inadequate fuel pressure, or clogging/failing injectors.
Old Nov 21, 2005 | 08:52 PM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
well i was having problems with my injectors awhile ago took 6 months for 3 different shops to figure out it was the fuel injectors, but i bought new ones and it was running fine, i have also check fuel pressure and its just right, so next i shall have to buy a vacume tester and work my way around i guess, also added drygas and fuel injector cleaner into tank to see if it would help, no difference......i have also recently replaced plugs, wire, cap and roter as well
Old Nov 21, 2005 | 09:12 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
i agree with vader i had similiar problem it turned out to be bad wires it started after bad raines. i ran through the list that vader listed.
Old Nov 23, 2005 | 02:53 PM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
is also just occured to me today, when i was getting on the highway i gave it some gas, she revved up, but diddnt go anywhere for a second or two, was wondering if perhaps it could be my tranny slipping, or should i take that out of the equation????
db057
Apr 28, 2019 07:45 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
