85 Trans am TBI??
Old Nov 22, 2005 | 12:46 AM
Big4x4Ride's Avatar
85 Trans am TBI??
Just go this 85 T/A, when the key is first turned to on it sounds like there is an injector pumping, and on the enige it looks like an injector, but looks like it s in a damn quadrajet? whats the deal with this??? I thought it would be TPI or 4bbl?? IS this some form of TBI?
Old Nov 22, 2005 | 01:54 AM
Firebat's Avatar
yes. Thirdgen's came with TBI. Dont know if 85's had them but its possible the car had an engine swap.
Old Nov 22, 2005 | 07:52 AM
Vader's Avatar
Some carbureted cars had electric fuel pumps. In '85, a TA would have had a QuadraJet or TPI. A base model may have had TBI - On a four cylinder. Either someone swapped engines, or it's not a TA, or it's not TBI.
Old Nov 23, 2005 | 10:24 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
MPFI- 2.8L
TBI- 2.5L
run your vin code, 8th digit, what is it ?
Old Nov 23, 2005 | 05:39 PM
Big4x4Ride's Avatar
the car is carburated, but has an injector type deal on it, clicks just like one. Maybe its just an electric controlled carb, not to familiar with the gm fuel system stuff.
Old Nov 23, 2005 | 05:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Computer Command Carburetor. Commonly called computer controlled carb around here, or CCC.
That's the Mixture Control Solenoid cycling. If you leave the ignition on but don't start the engine, it should stop in 10-20 seconds.
Old Nov 23, 2005 | 06:13 PM
Big4x4Ride's Avatar
thats it thanks
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
Dwayne614
Sep 28, 2015 08:33 AM
