cooling system mix... ?
Old Dec 4, 2001 | 09:12 PM
shafnbake's Avatar
Hey guys...
Sorry about the non-3rdgen post, but a friend of mine has a mid 90's W-body, and recently his 'low coolant' light came on. because he was in a rush, he ran up to his apartment, grabbed a glass of water, dumped it in the coolant overflow tank, and the light went off.
Now he's telling me that his car runs quite a bit hotter (usually over 220) then it used to. Could/would this be due to the improper mix of coolant/water?
Any thoughts would be helpful.
Old Dec 4, 2001 | 09:15 PM
breathment's Avatar
well, it depends, water has better heat transfer then antifreeze does, so it can actualy help the engine cool better. but antifreeze has a higher boiling pt. however, adding water wont cause the temp to just rise and hold. maybe hes just imaging it, or maybe the water was TOO cold. or maybe he doesn't have enough in it.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
64goatman
Sep 9, 2015 01:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
