why does it stall?
Old Dec 4, 2001 | 07:52 PM
irocaz28's Avatar
why does it stall?
my 88 tpi 5.7 stalls about once every 2 days when i put it into gear. Should i worry about that? And any suggestions of what to do?
Old Dec 4, 2001 | 08:02 PM
rezinn's Avatar
Could be many things. Does your check engine light come on ever? If not I would suspect that the bulb needs replacing, then you may be able to retrieve some error codes to remedy the problem. I would say its most likely a sensor problem. How does the car idle in park(and at what rpms?) after you start it?
Old Dec 4, 2001 | 08:04 PM
irocaz28's Avatar
the car idles at about 1300 when i start it and then drops to about 700 after a minute or two. the engine light does come on after IT STALLS.
Old Dec 4, 2001 | 08:09 PM
rezinn's Avatar
Are you able to retrieve any error codes? Find out here: https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
at the very bottom of the page.
Does this every happen after the car has been sufficiently warmed up? Any other problems like a rough idle?
Old Dec 4, 2001 | 09:05 PM
irocaz28's Avatar
well unfortunately i dont have a tester yet sop i dont know if any codes are coming up but the car runs fine otherwise. the idle is constant speed all the time.
Old Dec 4, 2001 | 09:20 PM
breathment's Avatar
well, actualy i bet u do have a tester, all u need is a paper clip.
does it only stall when the engine is cold? or all the time?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 4, 2001 | 10:38 PM
irocaz28's Avatar
mostly when the engine is warm. u get those cold start stalls evey now and then but thats normal. I forgot about that paperclip....thnaks
Old Dec 4, 2001 | 11:45 PM
shotgun's Avatar
Car: 89rs
Paper clip? Someone enlighten me on this new technology... seriously though
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
