rear main seal
Old Dec 5, 2001 | 06:05 PM
JaKeDaPlAyA's Avatar
rear main seal
if the rear main seal is bad..is it a must to replace the bearings?
Old Dec 5, 2001 | 06:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yikes, what the hell are you talking about?
If it is an '85 or earlier, you have to pull the oil pan and the rear main bearing cap, but you don't have to replace the bearing.
If it is an '86 or later, you pull the tranny and flywheel/flexplate and R&R it from the seal adapter, never touching the oil pan.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
