Rocker, cam and carb quetions
Old Nov 26, 2005 | 02:29 PM
littlekings's Avatar
Car: Dirt Street Stock oval track 2bbl
Engine: 350 w/dart iron heads and 383 w/world products sportsman II heads
Transmission: saginaw
What is the advantage of full roller vs. roller tip vs. stamped rockers? I know the rollers produce less friction but is there a noticeable difference? Has anyone ever checked on a dyno? I know the manufacturers are quick to say 3-5hp gains but does anyone really know?
Same type of question about roller cams. I know you can have more aggressive grinds but is the gain in the grind or the 'rolling' of the lifter? I guess it's a moot point because you need the roller to have the grind but I'm curious.
Also, anyone using Holley's Street Avenger carb? I am looking at the 670cfm for the BBC (467).
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
