distributor install
Old Nov 26, 2005 | 05:55 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
distributor install
distributor won't go in all the way, about an inch above manifold, I put a new coil in it and have no marks for orientation now. I need detailed directions on how to get it in the right way, I have cylinder one TDC from when heads were off...thanks
Old Nov 26, 2005 | 06:33 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It sort of twists about an 1/8th of a turn then goes all the way down.
Old Nov 26, 2005 | 06:38 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Take the cap off, grap the rotor and rotate it a little bit until it drops in.
TDC, yes. But TDC firing or TDC exhaust?
Old Nov 26, 2005 | 06:40 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You may need to turn the oil pump shaft a little, get a looong screwdriver and stick it in the hole turn the pump shaft, and try the dizzy again you may need to do this 3 or 4 times before it falls in.
Old Nov 26, 2005 | 06:47 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
TDC center for firing the exhaust was just starting to move when I left it, I am wrestling this thing right now, I broke the cap trying to turn it, I will try the long screwdriver thing right now and see if that helps
Old Nov 26, 2005 | 06:57 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
which way should the plug ins on the dist be facing?
Old Nov 26, 2005 | 07:01 PM
toward the firewall, arrange it so you have enough slack in the wires to turn the dizzy both ways to time it.
(by wires I mean the wires that go to the ignition module)
Old Nov 26, 2005 | 07:20 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
I still can't get it to go down that last little bit, I always read these things just drop in...it does not turn really easy when it is out, and once it gets down to a certain point being put in it is totally jammed
Old Nov 26, 2005 | 07:29 PM
is the hold down clamp in the way?
Old Nov 26, 2005 | 07:38 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
GM's hidden timing marks. They are in the back so you have to have a mirror to see them (handy). If you still have the factory intake and distributor they should be there. This is an '88 TPI motor.
Old Nov 26, 2005 | 07:47 PM
What do you mean by "does not turn really easy" that rotor should spin quite freely when out of the motor. Did you take the dizzy apart for something?
Old Nov 26, 2005 | 07:56 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
hold down clamp not in the way
I did replace the coil in the distributor and I think in does not spin very freely
I will look for the marks, but I am wondering if I assembled the dist. wrong
Old Nov 26, 2005 | 08:07 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
Supervisor42
I found the factory marks, that is really awesome, I was lining it up close to that mark and trying to rotate and it just seems like it won't go, it seems if the distributor was assembled wrong it would still slide in like it is supposed to, after all the work of a head gasket this is what is stopping me.
Old Nov 26, 2005 | 08:20 PM
Something doesn't sound right there,that rotor should spin free, is the shaft seated all the way in the body?
Did it turn freely when you took it apart?
Old Nov 26, 2005 | 08:24 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i hope your not trying to install this thing with the cap on...
Old Nov 26, 2005 | 08:31 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
I have no idea if it spun free when I took it apart, the coil covering was flaking off everwhere so I took it apart and put in a new one, now it won't spin freely at all. So normally you can grab the thing and spin the gear and it will keep spinning?
I have the cap off
Old Nov 26, 2005 | 08:58 PM
There will be a little resistance, if you give it a good spin it should go 2 or 3 revolutions anyway.
It's not going to freewheel, but it should spin without too much effort
When you put the dizzy in, the rotor will turn clockwise about an 1/8 of a turn when it meshes with the cam gear, the tab in the bottom of the distributer has to line up with the slot on the oil pump shaft, or the dizzy will not fully seat.
If I'm not mistaken the slot on the pump shaft is in line with the rotor, turn the pump shaft so it is also pointing at no.1 and the dizzy should drop in.
Old Nov 27, 2005 | 12:12 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I think JOhn89 is onto it.
I had a problem with the oil pump shaft slot (on the pump) being slightly off. It made re-install next to impossible.
I resolved the problem by shinning a light down the distributor hole and seeing how the slot in the shaft is oriented. Then turning the oil pump slot slightly to all it to line up with the distributor.
Best-
S-D
Old Nov 27, 2005 | 12:20 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Should the Dizzy base not fully seat you'll need to shim it with spacers, or the shaft will bind when you lock the dizzy down and the timing will drift will cranking and running until the engine is too far out of time to run, or start up. The dizzy will be damaged if you let it run this way too long.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
