Saw something on TV.. What do you guys think?
Old Dec 5, 2001 | 11:17 PM
XxMoLexX's Avatar
Ok i was jus watchin a TV show bout 4x4 driving.. anyways.. they were showing these "tough trucks" goin across wide open ice flats... anyways.. they had alot of .. i guess u would call it tire separations.... where the tire lost all inflation and was basically jus wrapped around the rim.. since they were in the middle of nowhere they came up with a quick idea to fix it.
They sprayed lighter fluid in and round the rim and tire... and lit a match... and the tire instantly inflated. Im not asking if it works.. cus i saw it... but wat i was wondering.. if this is a somewhat safe and slightly reliable quick fix ... if there is a situation where the tire loses all inflation and separated from the rim...
i dont think its too much of a common occurince for normal conditions.. but for hypothetical reasons...
any ideas on how many psi this could produce?.. and significant damage... if for no other reason i figure i would pass this on if its a somewhat reasonable option.
and i know its obviously dangerous to a point
White 91 3.1 RS.
T-Tops
12" Sony XS-l1235 Bass tube powered by MTX 2120 amp. Kenwood 8015 Head unit
16" ROH Rims
Firestone Firehawks
ES Urethane Tranny Mount
KYB GR-2 Shocks upfront
K&N Air Filter
[This message has been edited by XxMoLexX (edited December 05, 2001).]
Old Dec 5, 2001 | 11:22 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
This does not inflate the tire,it only seals the bead of the tire so you can put air in it. That trick has been around for years and works real good on big truck tires that are a pain in the a$$ to get the bead to seal on.
Old Dec 5, 2001 | 11:24 PM
Snuffit's Avatar
Car: 89 formula
Transmission: t5, soon to be t56
weve done that before with the off road jeep (brother and mines shared toy) to put it simply its a very BAD idea...yes it can set the tire back on the rim...it doesnt really inflate it...if you screw up you will be in some MAJOR pain...large tires can make very quick exits and they dont tend to slow down for little humans...btw if your feelin risky use carb cleaner...it works better...uh dont do it...its better to use the spare
Snuffit
R.I.P. 88trans am GTA
in memory of Katy
89 Firebird Formula 383tpi t56
[This message has been edited by Snuffit (edited December 05, 2001).]
Old Dec 5, 2001 | 11:25 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I've seen guys mount larger tires that way, blew a 33 12 50 on a steel 16x10 rim right off the tire machine and just about broke his leg....lol
I wouldnt advise it, but it works in a pinch.
As stated above, it just seats the tire bead.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited December 05, 2001).]
Old Dec 5, 2001 | 11:36 PM
XxMoLexX's Avatar
This makes sense... i dont feel as important now .. thanks for lettin me know...
White 91 3.1 RS.
T-Tops
16" ROH Rims
Firestone Firehawks
K&N Air Filter
Old Dec 6, 2001 | 12:01 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I think I saw the exact same thing on tv. Was it about Etreme Machines?
Old Dec 6, 2001 | 12:12 AM
lunas's Avatar
a freind of mine says they do this all the time in mexico rural areas where they cant afford anything else. take that how you want to
Old Dec 6, 2001 | 03:38 PM
XxMoLexX's Avatar
Yea big block it was.. on the Learning Channel
White 91 3.1 RS.
T-Tops
16" ROH Rims
Firestone Firehawks
K&N Air Filter
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
