Wire up a starter Q?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
How do you wire up a starter?
There is 1 big connection and 1 little tab.
Is the little tab a ground and the big gets power from the ignition?
I have a VERY VERY custom set up. So there is NOTHING stock on my set up. It is a summit SBC starter and it is a painless wiring harness (18 circuit hot rob harness).
Hope you guys can help so that I do not have to do trial and error thanks.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The big one is constant +12v from the battery and the small one is +12v from a switch (ignition or start button) The starter grounds through the block.
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
