can i put a helicoil inside a nut?
Old Nov 29, 2005 | 08:34 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
well i managed to mess up the threads in one spot on the nut thats welded to the other side of the frame, to mount my transmission crossmember. i can't really think of any way to change the nut short of cutting a hole in my floor and welding in a new nut. the threads are only gone in maybe a 1/4 inch spot where i went a little wide with the drill i was using to drill out a broken bolt.
will a helicoil work ok inside a nut? i'm guessing i do NOT want to just try and thread a new bolt in there with the 1/4 inch of thread missing?
Old Nov 29, 2005 | 09:33 AM
ede's Avatar
ede
you can put a heli coil anywhere you like, it isn't going to know if it's in a nut or an engine block.
Old Nov 29, 2005 | 10:30 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes it will work. another option is to retap the damaged hole to a different thread.
i had to do this recently to a buddies 92. he 3 stripped holes . i re-tapped all 4 to 7/16 - 14. worked great.
Old Nov 29, 2005 | 10:44 AM
1meanGTA's Avatar
good because i have to have my car ready to go by 6 pm tomorrow lol.
Old Dec 5, 2005 | 03:29 PM
1meanGTA's Avatar
well that didnt happen, i've had a lot on my plate lately and just today got the first bolt out. now onto the second one, i drill the hole, put in my extractor, which i guess was too small, and promptly broke off the extractor flush with the bolt.
i drilled a small hole next to it, about 1/8th or 9/64ths, to try and get a punch dug into the side of the extractor and back it out, but the angle i have to hit it at i'm hitting it more up than clockwise.
the steel on the extractor is too hard to drill through, my punch will barely dent it, and it smashed my chisel up. is my only option to take my time drilling small holes all the way around it to expose enough i can grab it with some pliers and get it out? is there any sort of dremel attachment i could get to more easily grind down the bolt? would have to be pretty narrow and long, i havent been able to find anything like that.
Old Dec 6, 2005 | 09:48 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Broken extractors really suck. I've had luck in the past hitting them with a hardened punch and a big hammer. If you can get a good hit on it, it will shatter. Being under the car will make getting a good hit tough. An air hammer would come in handy if you have access to one.
I had similiar problems with my crossmember bolts. I eventually cut a couple of holes in the side of the frame rail, ground off what remained of the built-in nut, installed a new nut and tack welded it in. Then welded the access holes back up.
Old Dec 6, 2005 | 12:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I drilled mine out & used 1/2" wheel studs dropped in from the top.
Old Dec 6, 2005 | 01:05 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Dont have to worry about it braking then i guess
Old Dec 6, 2005 | 01:21 PM
Ricktpi's Avatar
Overkill is my middle name
Actually they were readily available (Ford truck, I beleive) & worked out perfect.
Old Dec 6, 2005 | 03:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm surprised the nut is welded in well enough to even break off the extractor. I punched them out of the '86 donor car frame thinking I'd use them in the '82, which didn't have the back two holes needed for the longer TH700/T5 transmissions.
I ended up using hardware store nuts with fender shims for washers, slid into the frame from the frame section drain holes (which I opened up).
Old Dec 6, 2005 | 04:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
This happened to me, but the bolt broke in the nut. I drilled it ALL out to a bigger size removing the threads and all. I then put a grade 8 bolt and washer up inside the frame rail from the oval opening and fished it down 9 inches with those magnet arm things. After that the bolt fell through the hole. I then inserted an open end wrench into the opening to hold the bolt while i put the xmember back up and used a Nut on the bottom of the bolt.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89mulletbird
Aug 12, 2015 07:08 PM
