oil pressure confusion
Old Dec 6, 2001 | 03:41 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
My oil pressure on my 90 formula is goofy. Sometimes it works properly, but sometimes it drops when a load is on the engine. The pressure is fine at idle, but drops hard in fifth and sixth gear. Is this the pump, sending unit or what? Please help!!!!
Old Dec 6, 2001 | 06:34 PM
ede's Avatar
ede
i'd replace the sender and see what happens. cheap part and fairly easy to replace.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Dec 6, 2001 | 06:51 PM
82camaro's Avatar
Car: 82 camaro SC
It shouldn't be stationary--moving around is OK.
Stock guages and senders aren't that accurate--even when new.
The old 10 psi per 1000rpm is plenty of pressure.
We can tell you more if you give us a specific pressure at a specific rpm. In 5th and 6th gear the rpm is probably fairly low, causing a lower pressure.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 6, 2001 | 07:41 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I forgot to mention that the amp guage drops down to about 10 volts when this happens. The car loses no power and runs fine. It goes from about 30 pounds to 0 when I let out on the clutch at 1500 to 2000 RPM.
[This message has been edited by bingo (edited December 06, 2001).]
Old Dec 7, 2001 | 10:10 AM
82camaro's Avatar
Car: 82 camaro SC
Amp guage? You mean volt meter. Anyway, electric guages need the proper voltage to work accurately. Alternator should put it at around 14V at 1500-2000rpm.
82camaro
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
