Best plugs for 87 TA
Old Nov 29, 2005 | 10:01 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
What are the best performing plugs for a mostly stock 87 305 TPI. I have just a cold air intake a K&N filter & catback exhaust with an ADS superchip. I had Splitfire Triple Platinums in the car , but they fouled out & a mechanic told me platinum plugs with the small center electrodes like in the splitfire & bosch don't work well in this application.
Should I go with Rapidfires or some type of iridium plug or what? Any help with this would be appreciated!!!
Old Dec 2, 2005 | 02:58 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I like the rapidfires personally. What about the Delco platinums?
Old Dec 2, 2005 | 03:21 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
AC Delco R45TS ....good ol' Delco plugs work great. Forget about all the gimmiky fancy plugs stick to the basic cheap stuff that works great.
Old Dec 3, 2005 | 07:53 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
I have the AC Delco plugs in now, maybe I'll try the rapidfires next time around. I'm thinking an MSD ignition box would be a bigger improvement than just some fancy plugs.
Old Dec 3, 2005 | 03:41 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
From what i hear, top fuel dragsters run original champion spark plugs, and i'm sure if there was a single horsepower to be gained from one of those $10 spark-plugs they'd use them. Like i say i don't really have proof to back up my opinion, but from my past experiences the only difference i noticed from using NGK iridiums is a smoother idle. And dem plugs aint cheap, i'm certain that just a OEM-style plug will benefit almost if not as much as any other.
Old Dec 4, 2005 | 09:56 AM
vrtc350's Avatar
Car: 81 Corvette
I think you already have the best plug for types of engines. I like the rapidfires a lot as well but they are a little harder on the wallet. Especially since you have to buy 8 of them.
An ignition system will definatly give you a performance increase over any plug alone.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
