what cfm should i enter in DD2005 for mini ram
Old Nov 30, 2005 | 01:42 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
what cfm should i enter for desktop dyno for a mini ram using fel-pro 1205 or 1206 gasket?? Thanks
Old Nov 30, 2005 | 03:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I would use the cfm the throttle body flows unless it's a Forced Induction type then reference it from those specs.
That's about as specific as you can get with DD (at least the 2000 and 2003 versions I own). Other software like Virtual Engine Dyno (Digital Dyno Pro) I assume you can call part numbers out for a miniram.
Old Nov 30, 2005 | 04:12 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
ok thanks a lot
One more thing, what is the cfm for a stock throttle body??
Old Nov 30, 2005 | 04:24 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I believe the bone stock TPI TB's were rated for 600 or 700cfm
Old Nov 30, 2005 | 04:35 PM
Engine: 383 SBC
"The stock throttle body (48 mm) is rated for 650 cfm, ..."
Old Nov 30, 2005 | 04:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
See, i was damn close
Old Nov 30, 2005 | 07:25 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
thanks you guys, well im going to post what Digital Dyno Pro "said" my motor will create. This was a number I was around the number I was guessing.
Ill post it in a new thread
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
okfoz
Oct 13, 2015 02:19 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
