2 Quick Cam Installation Q's
Old Nov 30, 2005 | 06:41 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
I have an '88 w/ roller cam. When I put my new ZZ4 cam in and the plate on the end, there is about 1/8" play forward to back in the cam, is that right?
Secondly, should I install the cam straight up or 4* adv/ret?
Old Nov 30, 2005 | 11:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd say no, that's not right.
Are you using a cam button?
I'd install straight up.
Old Nov 30, 2005 | 11:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's with the timing set installed?
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't use a cam button with a factory roller.
It sounds alittle much to me, but I couldn't tell you off the top of my head what the spec is. Is this with the timing gear installed? I'm guessing not.
Straight up should be fine. Are you indexing it, or just using a 3-keyway crank gear?
Old Nov 30, 2005 | 11:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Should be about .008-.012", IIRC. With the timing gear installed, of course.
Old Dec 1, 2005 | 05:42 AM
MattODoom's Avatar
Car: '88 G T/A
Okay guys - I found out the problem with the play. I have a bad timing set/wrong one. Ill get the new one soon, should fix it.
So just go straight up? Its a 3 keyway crank sproket design.
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
drathaar907
Aug 6, 2015 04:20 PM
