My car cut off on me
Old Nov 29, 2005 | 02:12 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
I start backing out of the parking space and soon as I took my foot off the gas and before I could put it in drive and go it cut off and the SES light came on. I started it back up and the light went away, I put it back into drive and before I could push the gas it cut off again, but the light didn't come on that time. So again I started it back up and I just got lucky and was able to get on the gas before it cut off...... Then I was at a stop sign and it sounded like it wanted to cut off on me again, so I put it in neutral and it sounded normal, although it always sounds better idling in neutral than in drive because I have a rough/high idle when it's in drive but I can't tell where it's idling at in drive because the tach is broke.
Old Nov 30, 2005 | 10:19 AM
Kingsnake2005's Avatar
Car: 86 Camaro IROCZ
Engine: Stock 305 with 89 TPI
Transmission: 700R4 w/B&M transpak
My first guess would be the idle air control motor...
Old Nov 30, 2005 | 12:11 PM
nameinuse's Avatar
Or EGR valve/gasket.
Old Nov 30, 2005 | 10:46 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Yeah sounds like the IAC, you should run down to Checker's and have them scan for codes.....and make sure you haven't disconnected your battery because if so your codes might have been cleared.
Old Dec 1, 2005 | 12:26 AM
Doom Sayer's Avatar
What is Checkers?
Old Dec 1, 2005 | 01:10 AM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
if its a TPI i had something that sounds similar to that and it ended up being a couple things.
ESC Electronic Spark Control
plus i need a new cap and rotor
dont knwo if thatll help but since i changed that it hasnt happened to me.
Old Dec 1, 2005 | 01:22 AM
Doom Sayer's Avatar
It's a 3.1 MPFI
Old Dec 1, 2005 | 08:02 AM
Car: 1991 camaro RS
You should scan it for codes (check engine soon light) and also when your getting it checked look if the Idle Air Control is opening and closing like it should, and not sticking.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
mustangman65_79
Aug 13, 2015 07:36 AM
Sherpajames
Aug 7, 2015 06:56 PM
