camshaft question
Old Dec 8, 2001 | 06:06 PM
V6camaroman's Avatar
camshaft question
i was looking into getting a lunati bracket master camshaft. its got a .480 lift. i was also going to get 1.6 roller rocker arms. my question is with that rocker arm, camshaft combo will the valves hit the pistons on an otherwise stock 305?
Old Dec 8, 2001 | 06:24 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I don't know what type of 305, but if that .480 lift is before the 1.6 rockers then I don't think it's a good idea on a stock 305 since the heads probably won't flow it. Dunno if you'll hit the pistons or not.
91 Z28
Come see The Vicious...
Old Dec 8, 2001 | 09:33 PM
rezinn's Avatar
Without doing anything else, I wouldn't get that cam. Your heads probably won't flow any more than .450 lift could allow. Also.. I don't think your stock heads even support that much lift..with 1.6 rockers thats over .510. If this is using TPI I would look at a superstock L98 cam from LPE or a GM high perf. replacement cam.
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
