High fuel pressure...
Old Dec 3, 2005 | 03:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
My friend has a 88 maro with an lt1 from a 96 or so... basically its running like crap.. reason being is fuel pressure is way too high.. its running around 70 psi.. he's tried replacing the pressure regulator with another factory unit but still has 70 psi.. what else could it be?
Old Dec 3, 2005 | 03:47 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
A restriction in the return line? Does it stay at 70 psi during a WOT blast or drop some? What kind of fuel pump?
Old Dec 5, 2005 | 10:46 AM
89RsPower!'s Avatar
it stays, that was my guess too.. havnt tried anything yet though
Old Dec 5, 2005 | 12:52 PM
Vader's Avatar
I believe no one else has replied primarily because Lo-Tec nailed the cause. There's nothing else to say, other than we're waiting for you to find what the restriction is caused by.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
