quick question about oil dipstick placement...
Old Dec 3, 2005 | 04:37 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
for some reason whoever owned the car before me had pushed the oil dipstick tube back and zip tied it in place. this made checking the oil a pita because the dipstick would go back towards the hood when pulled out...
my question is, i just cut the zip tie and now the tube is easily pushed back and forth, is this normal? and how far up is it supposed to be?...i wish i had pics but i don't...
Old Dec 3, 2005 | 04:40 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
Re: quick question about oil dipstick placement...
I used a block from a 71 Chevelle and had the same problem.
Go to your autoparts store and buy a new dipstick the same size.
Put in a couple of times and silicone it in...I changed my oil right after just incase.
Mine hasn't moved an inch since I did it.
Old Dec 3, 2005 | 04:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
They are just a pressed fit so if it has been taken out or moved around alot it will get pretty loose.
Only a couple bucks for a OEM replacement or a few bucks more for a fancy chrome one.
Old Dec 3, 2005 | 04:47 PM
Trah84Z's Avatar
Engine: 305 V8
any problems with me driving with it like it is? sad thing i won't have a couple bucks till next week
and will i have to drain the oil when i change the dip stick?...
Old Dec 3, 2005 | 05:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
The only problem that will arise is if the dipstick tube pops out or moves up enough for it to start seeping oil.
You wont need to drain the oil when you replace it.
Old Dec 3, 2005 | 05:21 PM
Trah84Z's Avatar
Engine: 305 V8
awesome...thanks for the help...and i see you have two '84s...
Old Dec 3, 2005 | 05:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
alot of the cheap chrome tubes dont fit tight in the blocks
junk
so watch out on those
alot of use have good used ones laying around
what year engine you have ?
good luck
Old Dec 3, 2005 | 05:41 PM
Trah84Z's Avatar
Engine: 305 V8
all i know is it's a '84 305...i'm pretty sure it's a 305...
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
