Painting the inside of my engine
Old Dec 3, 2005 | 05:23 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
Yeah, I know it's old school, but, what kind of paint is the correct paint and where do I get it?
Thanks,
Steve
Old Dec 3, 2005 | 06:45 PM
ede's Avatar
ede
i use rustolium from walmart. pink is a good color.
Old Dec 3, 2005 | 08:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I think I did mine with Tremclad rust paint. I only painted the lifter valley. Just a small can and a 1" brush. Mine is gloss white. Took 3 coats.
Old Dec 3, 2005 | 08:59 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
You know my block was from 1980 and when I had it hot tanked in 2000 the inside of the block was immaculate and not one bit of rust. Its really unecessary from what i can tell. Ive never seen oil control issues either. If its not broken why fix it.
Old Dec 3, 2005 | 09:12 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Why not fill the oil pan with a couple gallons of paint and fire it up for a minute, that should git er dun!
Old Dec 3, 2005 | 10:13 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Amazing I love the old school tricks and i have never heard of that. Although you think the expanding/shrinking and just plain heat of the engine would pretty much put too much stress on the paint and make it start chipping and such. What is the purpose of this, rust protection, i always figured anti-freeze had additives to prevent it.
Paint in the lifter valley, any reasons. What does it help and is it worth the time.
Old Dec 3, 2005 | 10:32 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
you can also find clearance issues by looking for places where the paint is scratched off.
Old Dec 3, 2005 | 11:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I use it for oil control. The oil sticks to metal but quickly slides off the painted surfaces and back into the pan.
There's no antifreeze on the inside of my crankcase. At least not intentionally. Only in the coolant galleries.
Old Dec 4, 2005 | 08:00 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
It is exactly for what Stephen says, to get the oil back to the pan faster. It may be a bit superfluous, but every little bit helps. If oil is the blood of an engine, and the oil pump the heart, then it seems to me we want our hearts to always have enough blood to pump. Here is another tip I was told. Too much paint on the outside on an engine can actually prevent the engine from cooling. I guess if you think about it, it does make sense, but to what degree?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
