stupid FPR question
Old Dec 6, 2005 | 06:26 PM
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
stupid FPR question
to see if car is dumping to much fuel back into the gas tank via FPR every1 says to pinch or clamp the fuel return line. all i see is to thick metal lines, is there a rubber line somewhere that im not seeing? if so where is it?
Old Dec 7, 2005 | 04:57 PM
Engine: 305 tpi
any1
Old Dec 7, 2005 | 06:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What's your fuel pressure at the rails?
Old Dec 7, 2005 | 07:51 PM
Engine: 305 tpi
0 i have no fuel pressure, can hear pump run but get no fuel pressure, thats why i wanted to no about blocking the fuel return line, pulled line out of fuel filter and fuel came out with pump on, i think its dumping all my fuel back in to the gas tank via FPR.
Old Dec 9, 2005 | 12:52 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
that's a really really bad idea, your FPR is broken, repair it.
Old Dec 9, 2005 | 08:55 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Not really, it is a diagnostic method used by the dealership technicians. Check you lines, up by the motor, there should be short sections of flexible line. The smaller (diameter) of the two is the return line. Pinch it off, if you now have fuel pressure, you need to replace the regulator, if not.... Well, time to replace the fuel pump.
Old Dec 10, 2005 | 10:54 AM
That would be a decent idea, I thought he was going to pinch the metal line, that would've been plain crazy.
Old Dec 10, 2005 | 07:56 PM
Engine: 305 tpi
i wasnt going to pinch the metal line thats why i posted this question. thanx ploegi thats all i needed to know
Cleotiz
Jan 6, 2018 08:56 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
wayshegoes
Aug 17, 2015 12:00 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
