Over heating question?
Old Sep 25, 2001 | 06:33 PM
Team FTS's Avatar
My car usually runs at about 160 on the highway and 200 in the city , I removed my smog pump and now it runs at 220 highway and 240 in stop go, could it be the removal of the pump or something else?
Old Sep 26, 2001 | 06:38 AM
Vader's Avatar
Team,
The lack of air injection shouldn't cause any heating. What year/engine do you have?
Later,
Vader
Justice and Freedom will Prevail
Old Sep 26, 2001 | 09:30 AM
F_Bird89's Avatar
Have you checked for coolant leaks/loose hose connections?
Kevin
Old Sep 26, 2001 | 05:38 PM
Team FTS's Avatar
I have a 91 Trans-Am TPI
Silly mustang's speed is for F-bodies
Old Sep 26, 2001 | 06:14 PM
89Irocz23's Avatar
ok well you may have done the belt routing wrong and the water pump is spinning fast enough. Take your radiator cap off and start car and see if the water is flowing good or not, but make sure to put the cap back on before u turn car off. That is the only thing I can think of why is running hotter. The belt not be on right and the pump is spinning fast enough or something.
Old Dec 11, 2001 | 10:16 AM
Team FTS's Avatar
I followed the instructions off of the site and bought a inch longer belt and routed it the way the tech article sadi, has anyone else had this problem?
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
