Self-tune up?
Car: 1991 Camaro RS
Engine: 5.0L 305 V8
Transmission: automatic
Self-tune up?
is a tune up somthing i can easily do myself? or can i have my mechanic-friend do it? how much do you think it would cost??
-thanx
-thanx
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you can do it yourself.
tune-up is an old phrase from way back, now there isn't much to "tune up" anymore, as it's all computer controlled.
you have an RS, so TBI injection right? check/replace air filter, fuel filter, check belts and hoses. Check spark plugs.
no carb or timing "tuning" necessary.
Car: 1991 Camaro RS
Engine: 5.0L 305 V8
oh my gosh thank you. I already replaced the air filter, even though it was almost spotless. i wanted a K&N anyways lol. so that just leaves fuel filter and hoses and belts. that just saved me lots of trouble.
thanks
thanks
Car: 1982 Trans-Am
I guess that isn't distributor less ignition, so perhaps the rotor/cap could be replaced....
But yea, it's a screwdriver and pliers sorta job, no fancy tools needed unless something is actually wrong.
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Spark plugs never hurt anything, and if your taking them out to look at them you may as well replace them if you know they haven't been done. Wires too if they look old, but it isn't necessary unless theres a problem.
Dist cap and rotor makes you feel like you did something
327_TPI_77_Maro
Alternative Port EFI Intakes
Oct 17, 2011 04:24 PM
mistaben
Oct 5, 2011 09:30 AM
