Leaking antifreeze from intake???
Old Dec 10, 2001 | 02:39 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
On my 86 IROC behind the pasenger side valve cover there are pols of leaking coolant intot he valleys of the intake,where could this be coming from intake manifold gasket???craked intake??????
86 IROCZ 5.0 TPI/"new" 700R4 auto with transgo shift kit and vette servo,canary yellow,t-tops,radar detector,tan interior,hidden antenna,tinted windows,taillight blackouts,front end bra,k&n air filters,no cat,full 3" racing exhaust with 40 series flowmaster and chrome tips,2:73 posi rear(soon to be 3:42 or 3:73 posi),1989 IROCZ 16*8 polished aluminum rims
Old Dec 10, 2001 | 03:59 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Yeah, its probably coming from the head gasket on the passengers side.
Check the oil and see if it has a milky texture to it. It could also be the heater valve, which will crack and leak...
Get the problem fixed though, its never good.
Thats how I lost my 305.
Mike
Old Dec 10, 2001 | 09:50 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Most likely its leaking from the intake gasket or water outlet.
Ive never seen an intake crack.
The intakes are known to pit from corrosion around the water passages, and need to be replaced.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited December 10, 2001).]
Old Dec 11, 2001 | 12:00 PM
burntblues's Avatar
Car: 1989 Camaro RS
yeah, I've never seen the intake crack either, but the heater valve will, which will cause a slow leak. It is almost definatly the intake gasket though.
Mike
Old Dec 11, 2001 | 02:16 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I've seen a cracked intake, actually did it myself.
Turns out the intake was made of PLASTIC.
And it was on a FORD.....go figure.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
