What would it take to run 13's w/ a 350 in an 83 T/A?
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Im getting rid of the LG4 pretty soon. I have a 350 to build. It has 1.94 heads with 76cc chambers. Are these bad? The motor is a 1976 truck motor. What do you guys suggest as far as pistons, cam, intake, heads, and carb? I already have 3.73 gears w/ a good posi, so Im set there. I want to at least run consistent high 13's while tetaining my emissions equpiment and CC Q-Jet. THX
1983 T-top Trans Am. All stock (for now) LG4/auto/3.73 posi. 70,000 original miles. SLOWLY going through a Knight Rider conversion. (it will be done one of these years)
Bset of 15.79@86mph 2.16 60ft
1963 Dodge Dart drag car. 360/904/4.88
Best of 10.94@120.44mph
Car: 1989 C4
Axle/Gears: 307
AS the owner of a 76 truck I can say the block, rods and crank are the only good parts. The heads suck, cam sucks, you get the idea. In 76 the good 350 engine only put out 160hp there was one that only 140hp
I'll post beck later with the mods that got my car into the 13's. Have to go on call.
SSC
85 Camaro Z28, Cowl induction hood, Black-355/TB400,3:42 posi, Tons of goodies but if you ask, "Its stock
82 Firebird, White, red in six months-355/TB350,3:42 Powertrax posi. Not an insane amount of goodies but it runs like a motha!
76 Chevy C10, Firemist blue, 355/Muncie HD 3speed,3:73 TorqLine posi. Show me another 12sec@4800ft SBC street truck??
91 GMC 1500 Sierra 4x4, Red, Was 4.3 now the proud recipient of the Firebirds LG4. 305/5 speed.
56 Buick Special, OG Blue&White, V8/auto. Maybee one day I'll get it going.
SSC
" 82 Firebird, White, red in six months-355/TB350,3:42 Powertrax posi. Not an insane amount of goodies but it runs like a motha!
Car: 1989 C4
Axle/Gears: 307
My 85 camaro has a 355, flat
tops 4valve relief pistons "not really flat tops huh?", 58cc heads from an Lg4
mildly ported, stock valves, comp270H cam, comp springs, 1.6 RR, Wieand stealth holley
SA670, 2.5 Dual exhuast w32in glasspacks, MSD6al<--IMO junk, blaster 2 coil accel
distrubutor, good old 8$ fuel pump , turbo 400 1800 stall converter 3:42 posi. I could possibly break into the 12's If I used headders.
I know bot all of this is doable for your application, but alot of it inst nessasary. I run @ 4800ft above sea level and if your lower down than you could get away with half of my mods and get to your goal.
I would reccomend that you get your whole rotating assembly ballanced to start with then choose a cam that suites your needs and match with good tripple springs. Then get the proper stall converter to match your cam's powerband and rear gears.
Oh and say by to descent fuel milage
SSC
[This message has been edited by SSC (edited December 10, 2001).]
SSC
SSC, Im wondering, what is your compression ratio with the 305 heads? I have a set of L-69 heads and was thinking of trying them on my 355 which is real similar to yours. How does your motor do for power? Seems like it would be real torquey but run out of breath quick? TIA.
I would say that 305 heads are good because they will give you good compression, but they will need some work. Why dont you run Vortec's? They are cheap (probably cheaper than the machine work and valve job on your 305 heads) and flow well (again probably better than ported 305 heads). A carb setup ontop of these heads will definetly give you 13's when paired with a decent cam. Are you planning to run any spray later on? If not summit sells rebuild kits with flat top hyper. pistons real cheap. You could probably run 13's with the stock carb and keep better gas mileage.
If you dont have the extra $$ the 305 heads will work for ya. Keep doing what youre doing and talk to people with different setups. I wish I could tell you about my 13 second setup...maybe someday
Good luck
. Good luck
Car: 1989 C4
Axle/Gears: 307
It's estimated at 12:1. The camaro has 1.84 in valves and it runs great to 6200rpm. The heads were mildly ported on that. The truck has 1.94in on it and very ported heads it and Ive had it to 7k any higher and the valves float. I personally want to get 2 sets of 64cc heads and have them worked over so I can run more advance also more N2o. But these engines run very strong both top and bottem and besides a few sets of heads gaskets on the truck (too much N2o) no problems besides 91 max octaine. LOL.
SSC
SSC
Transmission: 4L80E/4L80E
GM HO 350 Conversion Kit w/ZZ4. High 13's at sea level, put headers on it and you should be able to make those 13's at your altitude uncorrected.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
raymondandretti
Sep 27, 2015 06:43 PM
