Have a strange problem
Old Dec 11, 2001 | 06:26 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
I have a 1992 350 TPI car
My problem is this
If I am hammering on her good (WOT) I get a stop pulling condition at 4500 or so RPMS. The car will not shift nor pull any further than that. Almost like I have hit the rev limiter. If I let off of the gas it will shift and then run up to 4500 or so again and do the same thing. Does no matter if the car is cold or warm still does it.
If I run it up slow it will go all the way to 6K rpms. If I roll into it and do not go WOT from the very begining it does fine.
Does this under WOT only.
Also if this matters it is a 92B4C car. tpi 350 with the 700r4 tranny.
Completely stock setup except for a mild port on the upper and lower intake, a catback and a K&N filter.
Please help
Old Dec 11, 2001 | 09:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Try adjusting the TV cable..do a search, I understand the Tech Article is unclear.
Old Dec 11, 2001 | 10:07 PM
breathment's Avatar
check the volts on the TPS at WOT. maybe something is up with that.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
http://www.geocities.com/david_angel_16
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
IROCtometal
Sep 2, 2015 02:01 PM
