2 bolt/4 bolt "main"? Blocks???
Old Dec 11, 2001 | 11:56 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
Im wanting to buy a 350 block and build it from scratch, it would be a good learning process since Im a super newbie at this. When I get a block, do I want to get a 2 or 4 bolt main block for my bird? What does this mean?
87 FireBird Formula
305 4bbl LG4
K&N Filter
Flowmaster 80 Series
P215/65R15 Tires
Clarion ProAudio DB315 Deck
MTX Thunder6000's 12" subs
Jensen KA3 500 Watt Amp
Pioneer 6x9s Ts-A698
-----Need Upgrades-----
--Give suggestions plz--
BuddyLee's Thirdgen Project
Old Dec 12, 2001 | 12:00 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Depends on what your planning on. 2 Bolt blocks are fine and can be taped for 4 bolt mains or you could get good main caps that will hold up to severe duty. IMO if you have to pay more for a 4 its not worth it but if you can get one for the same price go with the 4.
SSC
Old Dec 12, 2001 | 12:04 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
2 bolt blocks have 2 bolts on all main caps.
4 bolts have 4 bolts on 3 of them.
For the street, 2 bolt is usually just fine...it can handle a good amount of power.....now if you are going to with a nitrous shot....
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Dec 12, 2001 | 01:19 AM
ronterry's Avatar
Car: '94 Corvette
A good BALANCED 2 bolt can handle 500-600 HP, and 7000 RPM's. Same with a factory forged crank (I was thinking that would be your next question ???)
BuddyLeeX if this is your first keep cheat, don't start making strokers, or droping hard earned money on thousand dollar 4340 cranks.
Let the machine shop do all the hard core block work, and I'm sure they have some 350's laying around. The best place to get a crank is at a crankshaft specialist, they have better tools for that, and believe me they will get your tolerances with in limits, and not sloppy like some machine shops I've seen. PLEASE get your assembly balanced (Crankshaft guy will do that, and they will give you a print out), to many people overlook this insurance.
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
'00 Impala LS
Old Dec 18, 2001 | 06:39 AM
agawam's Avatar
2bolt or 4 bolt doesn't make much difference for a street engine, I like to use ARP studs in the mains
Reddeath210
Oct 6, 2015 08:20 AM
Accerrito22
Aug 23, 2015 07:22 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
