What is Boring?
Old Dec 12, 2001 | 02:46 AM
Ride4ME's Avatar
What is Boring?
What does the task of "boring" called for
and what is machining?
Old Dec 12, 2001 | 04:09 AM
kingtygr's Avatar
Boring is when you increase the diameter of the cylinders a small amount to give them more volume, hence extra power. machining, that's when you grind, cut, or similarly modyify the metal on the block, crank, heads, etc.
Hondas get all the girls.
Camaro's get all the women.
'89 Camaro RS T-top L03, T5, 3.08 10 bolt stock rear, Edelbrock Pro-Flow filter, more to come as the money flows....
[This message has been edited by kingtygr (edited December 12, 2001).]
Old Dec 13, 2001 | 08:13 PM
Guest
Guest
Posts: n/a
Boring is actually done when the cylinders are worn, they use a special tool to machine the bores in the block so they are completely round and the same diameter from top to bottom. Any power difference will be minimal with a typical overbore.
Old Dec 18, 2001 | 10:23 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
boring is when you go to the in-laws for Sunday dinner and sitting around talking about nothing. (Sorry)!
Old Dec 18, 2001 | 10:44 PM
Nitroburn's Avatar
I second that !!!!!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
hartsmike
Oct 2, 2015 07:11 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
