fuel problem
Old Dec 12, 2005 | 08:45 PM
DansZ87's Avatar
Car: 91 Z28
Transmission: 700 R4
fuel problem
got a serious problem, car wont start, i think its not getting any fuel, i usually here the fuel pump prime and now it doest, i had to replace the battery and put a new one in now no fuel, what should i do, i have to have the car to emissions in a few days, thanks a lot for any help
Old Dec 12, 2005 | 09:20 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
check your relay. jump the orange and grey wire to see if the pump comes on. If it does then the relay is most likely the culprit. If not, check the connectors at the tank and hopefully it isn't the pump itself.
Old Dec 12, 2005 | 09:23 PM
DansZ87's Avatar
Car: 91 Z28
a
how do i jump them, just cut them from the harness and wire them together ??????????
Old Dec 12, 2005 | 10:03 PM
1981LT1's Avatar
Engine: LT1; LT1
grab a piece of spare wire or use a paper clip and some insulated pliers.
Old Dec 12, 2005 | 10:41 PM
DansZ87's Avatar
Car: 91 Z28
ummmmmm
Old Dec 12, 2005 | 11:41 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
If the engine crancks but no fuel check the fuse next to the battery. Its on the fender next to the battery. Open the protective case and you will see it.
If that does not fix the problem there is a wire that you can cut and splice in a power wire to see if the pump works. However I think its the fuse. If not I'll let you know how to hot wire the pump. Or u can ask trickster on the Electronic board!!!
Old Dec 13, 2005 | 10:12 AM
DansZ87's Avatar
Car: 91 Z28
gi
the fuse is good, i had this problem before, and i ungplugged some relays and plugged them back and it worked, but not this time
Old Dec 13, 2005 | 01:46 PM
DansZ87's Avatar
Car: 91 Z28
well i unhooked the battery then hooked it back up, and it fired right up? dont know why it did this before any takers?
Old Dec 13, 2005 | 04:19 PM
Corrosion!
Old Dec 13, 2005 | 05:16 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
ecm lost settings
Old Dec 13, 2005 | 08:15 PM
I bet your terminals werent all the way in or stripped!! The ground on the block can also be the culprit.
Old Dec 13, 2005 | 11:03 PM
DansZ87's Avatar
Car: 91 Z28
thanks guys
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
