torque settings, aluminum heads
Old Dec 13, 2005 | 04:33 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
Installing the headers on my new ZZ4.
This might be a dumb question, but are the torque settings different between cast iron and aluminum heads?
Old Dec 13, 2005 | 05:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Same specs and sequence. Torque specs pertain to the fasteners, not the material being fastened.
Old Dec 13, 2005 | 06:25 PM
Engine: ZZ4 TPI
Thanks Stekman, I never knew that.
Old Dec 13, 2005 | 09:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
are the threads in the material helicoils? or is it threaded AL? (never worked with AL heads before...)
just wondering, 'cuz wouldn't the headers, now bolting to an aluminum head instead of an iron head, take less torque? I figured the threads would pull out of the AL easier then iron.
Old Dec 13, 2005 | 10:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I do 25lbs for both.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Navy8125
Aug 22, 2015 07:13 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
