Engine apart now what??
Old Dec 15, 2005 | 10:42 AM
ssscarpone's Avatar
Car: 1983 Pontiac Trans Am
Engine: 305 Crossfire V8
Transmission: Autotragic
Is there anything I should do to the intake manifold and intake plenum or dual cfi's while I have it in pieces?
Also I screwed up and let leaves and dirt go into the heads and stuff how big of a deal is it?? I put a pic up for u to see.
Old Dec 15, 2005 | 10:44 AM
ssscarpone's Avatar
Can u Mod these at all?
Old Dec 15, 2005 | 02:14 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Re: Engine apart now what??
Originally posted by ssscarpone
Also I screwed up and let leaves and dirt go into the heads and stuff how big of a deal is it?? I put a pic up for u to see. [/B]
Not a big deal at all. Leaves are very combustabile so it will be like adding nitrous to your motor. The dirt will accumulate and help raise compression. Also increasing horsepower.
No jack it up like a ***** and go roast some rustangs!
Old Dec 15, 2005 | 02:24 PM
Guest
Guest
Posts: n/a
Most of that stuff will blow out the exhaust when you fire it up. Hell, may even clean out the carbon deposits on the way out.
Old Dec 15, 2005 | 04:34 PM
ssscarpone's Avatar
what the hell is this thing?
Old Dec 15, 2005 | 05:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
oil pressure switch for the fuel pump.
Old Dec 15, 2005 | 06:48 PM
ssscarpone's Avatar
thanks for the info
Old Dec 15, 2005 | 07:46 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Re: Re: Engine apart now what??
See my Avatar......
thanks, I needed a laugh after a long week, which included a trip to the dentist- and work was even more painful!. Humor.
Triple S-
Not sure what your plans are for your engine, but it likely needs significant cleaning if it is cheesed up as depicted in your photos and described in your post.
It is basically a matter of knowing how much time and money you wish to put into the engine and how many times you are willing to spend time and money on the engine.
I personally would pull the engine and go through it- it may be cost less in the long run- if you keep it.
But I don't know if you are looking to keep the car and drive it or keep it and race it or sell it to some poor unsuspecting schmuck.
That makes a difference in the game plan.
Can you provide more details of the overall plan?
Best-
S-D
Edit-
I don't see too many pine needles hanging out the head ports, but I do see some anti-freeze in the lifter valley.
Not sure how much anti-freeze made its way into the pan. If you just lightly clean re-asssemble, change the oil first- anti-freeze is hard on bearings.
Old Dec 15, 2005 | 08:33 PM
ssscarpone's Avatar
Re: Re: Re: Engine apart now what??
swerve-driver
i am not sure what to do.. it is a car i bought for 750 bucks
has a c box title
tranny is jacked but could be fixed by wiring
i cant do a motor swap because of emissions.
i have already put 400 in it just to get it going.
so i dont know
any ideas
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
