Need help identifing a fluid leak
Old Dec 15, 2005 | 03:55 PM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
All right guys, I need your help in telling me what a clear-yellowish fluid could possibly be leaking from my engine. The puddle in my driveway is getting bigger everyday and it is worrying me. I don't want my car to break again because of a fluid leak. If you know what it might be and if you could tell me where it could be coming from, I would be very thankful. Decided I would ask you guys first and then a mechanic. Since you guys know the third gens very well. BTW if you need to know, the engine is the stock 305ci 5.0L H.O. and its carburated. Hope that helps you with finding it out.
Doc Holiday
Old Dec 15, 2005 | 03:58 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Sounds like antifreeze.
Im not sure if your up to it but if i suspect a/f i dip my finger in it and taste it to see for sure. if your lucky it wont be cat **** lol
BTW, do you play counterstrike by chance? theirs someone on the server i play with by the name docholiday
Old Dec 15, 2005 | 04:18 PM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
Hahahaha, yeah I'm pretty sure its not cat ****! To thick to be. (I touched it). And yeah, I do play Counter-Strike: Source. What server do you play on? I played for a clan called Egokillers, and I played for one called Blindside. But life has taken me away from the joys of CS:S.
Doc Holiday
Old Dec 15, 2005 | 04:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
(HOP) House of pain, thats the only cs:s server i play on.
Old Dec 15, 2005 | 11:43 PM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
Hmm never heard of house of pain. Also, I will be going to AutoZone and possibly my mechanic to identify the exact fluid that is leaking. What color is powersteering fluid? I know you guys said it is probably anti-freeze, but this fluid has a thick consistency to it. I don't know what to do. All I see when I look at that puddle is another $750 dollar repair.
Doc Holiday
Old Dec 16, 2005 | 12:03 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
PS fluid is usually clear, some i have seen have a bit of a pink tint to it though.
Why not just look around for whats leaking...
Check fluid levels. If a/f is low thats most likely the problem, if PS fluid is low that could be it.
Old Dec 16, 2005 | 12:06 AM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
I'll do that tommarow. Its already 11:00 at night where I am. Whats wierd is when I look for the leak, I can't find anything, but the driveway tells it all! But I will get under the car tommarow. Thanks bud.
Doc Holiday
Old Dec 17, 2005 | 02:07 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Check you overflow tank, if it's empty or low, your prolly leaking coolant. Start her up pop the hood and inspect. Check all your hoses and look. Look nice and hard. Try revving it up and see if you notice any spraying/leaking. Isn't it great owning a GM product!? So many problems already!
But like 84z28350 said, check all the fluids. Can't hurt to make sure your in tip-top shape. It's a old car, who knows when they were last checked/changed.
Old Dec 17, 2005 | 04:21 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Just taste it. If it's sweet, you know exactly what it is. I've done it before. A tiny bit on the tongue will not be harmful.
Old Dec 18, 2005 | 02:16 AM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
Well I solved this problem. When my mechanic overhauled my carb, they filled up the antifreeze to much. So when my car was running hot she had alot more than she could hold. So she dumped it on my driveway via the overflow. Nothing big and major. Found that out before reading these posts. But to see my bigger problem, go here.
Help Me!
Doc Holiday
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
jrdturbo
Mar 31, 2016 02:58 PM
HikoriYami
Sep 21, 2015 07:11 PM
Stryker412
Sep 20, 2015 06:59 PM
