Converted from TPI to Ramjet - Now it's way too rich???
Old Dec 17, 2005 | 03:30 PM
1badmopar's Avatar
Car: 1966 Plymouth
Engine: 520" RB
Transmission: 727 Torqueflite
I just converted my s10 from L98 TPI to GM Ramjet injection and Vortec heads. I am still using the L98 ECU. Now it is running way rich. When I plug in my wideband it shows to run around 12:1 - 11:1 at wide open trottle. It just has stock LT1 injectors. I also tried a set of 19 lb Mustang GT injectors and it showed the same condition. Fuel pressue can be adjusted from 20 lb - 45lb without much impact.
FYI... the Ramjet uses different TPS and MAP than the L98. I just cut the harness and spliced the wires.
Old Dec 17, 2005 | 06:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
12-11 AFR actually sounds about right for WOT running to me, whats the problem?
Azrael91966669
25
Jun 20, 2017 04:04 AM
dyeager535
Aug 28, 2015 08:10 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
