10 gallon gas tank?
Old Dec 17, 2005 | 08:36 PM
baymarauder's Avatar
Car: '92 Camaro RS - gone
Engine: 305 TBI
10 gallon gas tank?
OK I just got my car a week ago, and I filled her up just today. I only put 8 gallons in and the fuel guage read almost full! Is my fuel tank only 10 gallons??
Old Dec 17, 2005 | 10:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Odds are its probably just a bum sender in the tank indicating empty when there is more gas remaining.
Old Dec 17, 2005 | 10:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Or it's just a sticking a bit. Perhaps try tapping on the bottom of the tank with a rubber mallet to see if it gets freed up.
Old Dec 17, 2005 | 10:55 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
just dont pound a hole in it the smallest gas tank they put in a thirdgen was 15.5.
Old Dec 18, 2005 | 11:00 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Full tank =16ish gallons
Full on gas gauge= 11ish gallons
If you top off your tank your fuel gauge will probably be well past F. It has been in every 3rd gen of mine. Why don't you top off your tank and find out?
Old Dec 18, 2005 | 01:42 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
My gauge reads from the Empty tickmark (when the needle aligns with E, I'm OUT - engine dies) up to ~1/8 tank above Full. The 1/2 mark is really ~1/3 tank and the 3/4 mark is really only about 1/2 on my car, at least.
If I run my tank dry enough to kill the engine (only happened twice...), I can only fit in about 14.8 gallons. I think the shape of the tank is a little strange with the internal baffles. Maybe they trap air?
gta892000
Aug 11, 2019 11:16 AM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
