Engine running rough, need help!
Old Dec 19, 2005 | 12:11 AM
formula_k's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 5.0 Liter (305ci)
I have an 89 Formula with a 305 TBI in it. When I first got it it ran fine on the way home, when I got it home I went to move it and it ran like crap. My buddy opened the hood and pointed out one plug wire was arcing on the manifold. I taped it up, obviously not too professional but I wanted to see if it would work, and that didn't help any. I changed the plugs as well, still no help. I gave up on the car and planned to sell it, but now I'm back from college on winter break with a renewed interest in taking this car back to school. I don't know if changing the plug wires will help or if it's something else. It idles kind of ok until I put it in gear (auto), then it bogs down. When I try to drive it, it has NOOOO power when I give it gas, I have to push the pedal back and forth to ease power into it or it will stall. There is also a tick coming from the timing chain cover so I think it needs a timing chain as well that I plan on changing, I was just hoping to get it drivable to get it to a mechanic to change since I have limited time. I was also thinking it could be the distributor or the cap/rotor. Any help on this matter would be greatly appreciated!! Thanks!
Old Dec 19, 2005 | 03:40 AM
StaticVertigo's Avatar
do a general tune up. new plugs, cap, rotor, then check your firing order.
Old Dec 19, 2005 | 10:47 AM
formula_k's Avatar
OK, will do. I'll let ya know how it turns out.
Old Dec 21, 2005 | 09:30 AM
berlincam86's Avatar
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
if nothing else works try the egr valve i had that same problem before and the egr valve was stuck open.
Old Dec 23, 2005 | 11:47 PM
formula_k's Avatar
So it turns out it wasn't the car, I'm just an idiot who didn't calculate things. 5 dollars of fuel, or about 2 gallons at the time I brought it home, and about 30 miles. I put some STP gas treatment to get the bad stuff out of what old gas remained and put in about 5 gallons of midgrade fuel and now it runs fine. Lol all that time I thought it was broke. Thanks a lot guys, and I'll be sure to check and make sure the EGR valve is ok too!
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
