Will this cone K&N flow enough???
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i bought this cone K&N form summit http://store.summitracing.com/defaul...F-1015&FROM=MG and am begining to wonder if i should have gotten a bigger one instead http://store.summitracing.com/defaul...E-0870&FROM=MG .
basically one is 7" long and the other is 9" long...oh and the one i got (7") didnt have the chrome end cap like sumiit said on their site
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
yup, pictures looked the same & they both said 900 cfm, which is probably not true being that one is bigger...
a stock 305 uses between 400 - 450 cfm I think, when I was doing my volumetric efficiency research...
Car: 1991 Z28
Engine: 383
o yea motor specs would help...
383
trickflow heads
cam similar to 282hr
HSR
i konw there is a maximum of 900cfm that k&n filters will flow but i just want to make sure this will be sufficient for my motor.
thanks
383
trickflow heads
HSR
thanks
Okay, one question how the hell did you link from Summit? Am I the only one that has trouble linking from them?
Also, on a 383 like yours, I would have gone with the bigger 9" one. It can't hurt to have a larger filter right?
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have a filter just like the RE-0870 on my car but with the 3.5" inlet diameter. My engine is a 355. On the dyno the horsepower did not change with the filter removed. So it flows more than enough air for my combination. Rule of thumb is to buy the largest filter that will fit.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
this is the one im using:
http://store.summitracing.com/partde...5&autoview=sku
its huge, and looks like a giant donkey dong...
14" long
4" outlet...
14" long
4" outlet...
Car: 1991 Z28
Engine: 383
lol, nice way to describe it.
i wanted to go with the 9" but im putting it right underneath the pass side battery tray (made a new battery tray and am moving the batt to the back) and there is a brace that runs down there and might have possibly gotten in the way.
i hope if this does cost some HP it wont be much compared to the 9"
Car: 91 Camaro Vert
Car: 1991 Z28
Engine: 383
nice. thanks, i like that little calculator. i need almost 690cfm at 100% efficiency which i will never reach so i think im good. i just dont know the specifics of what this filter will flow.
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
i'd bet at least 650
which is all you'll probably ever use with that setup
i wouldn't worry about it
yank it off for a run or two if you ever dyno tune it, then your mind will be at rest
dyno tunes are good for you anyways... gets the most power out of your setup with the best gas mileage (usually)
Pac J
May 17, 2020 10:44 AM
