305 problems
Old Dec 21, 2005 | 02:16 PM
streetassasin's Avatar
Car: 2001 SS
Engine: bolt on LS1
305 problems
ive got a 89 rs with a tbi 305 sometimes it will just die while im driving then start right back up then run perfect. Now its starting to not want to rev up while in drive u can floor it and not go over 10mph put it neutral and it wont rev over 3500 rpm, but if u shut it off then crank it back up it runs perfect. Does anyone know whats wrong with it?
Old Dec 22, 2005 | 07:56 AM
Vader's Avatar
Was this car in the flooding from the storms earlier this year? I'd suspect an exhaust restriction, and if the car has been underwater, the converter would be my first suspect.
Weak ignition can also exhibit those kind of symptoms.
Old Dec 22, 2005 | 11:13 AM
Car: 2001 SS
Engine: bolt on LS1
Thanks for the help ill check into a converter as soon as I can. It wasnt in any storm we took it when we left for the hurricane and it did it then to.
Old Dec 22, 2005 | 11:42 AM
Vader's Avatar
I believe most muffler shops (at least the chains) have a test gauge that can be connected in place of the oxygen sensor to test system backpressure. If the converter is clogged, muffler is collapsed internally, or pipes are consrtricted, the gauge will help analyze it.
Old Dec 22, 2005 | 12:26 PM
Car: 2001 SS
Engine: bolt on LS1
I plan on getting a flowmaster catback installed next week so ill see if they check it. I got a quote on a converter from them and it was $150 I thought it was kinda high. How much should they charge to check it?
Thanks again
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
