1970 XF code 455
Old Dec 22, 2005 | 06:14 AM
Kross4031's Avatar
Car: 86 IROC
Engine: Pontiac 455
Transmission: TH350
1970 XF code 455
i have figured out that i have a 1970 455 casting date 9-9-69, casting code XF, casting code 64 on the heads. it is a complete numbers matching engine. anyone out there know if this engine is rare or worth the money put into it?
Old Dec 22, 2005 | 09:29 AM
Vader's Avatar
That looks like a Pontiac engine. You're gonna have a little trouble with the crossmember on that Playskool trike, for sure...
1970 Pontiac 455, 370 HP, XF Block, Auto trans, 10.25 CR, 067 Cam, 64 Heads, 1-4 BBL Carb, Carb No. 7040268, Grand Prix /1970 - Only hi comp 455/with 15 or 64 heads Block Casting # 9799140
That is from http://www.wallaceracing.com/enginesearch4.htm
Old Dec 22, 2005 | 10:12 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd say that's worth money to someone restoring an old pontiac. Depends on who you can find to pay for it. Ebay would be the best place to find a large amount of people, i'd recommend posting it there...
Old Dec 22, 2005 | 02:12 PM
Kross4031's Avatar
Car: 86 IROC
Engine: Pontiac 455
Transmission: TH350
ebay is what got me curious about if this engine was anything special. there is a fellow asking 7500$ "but it now price" for a 71 455 YE casting code. this motor was in peices, half of which were still covered in crud. it had some machine work done to it. 4 sleeved cylinders. alot of money for something not anywhere close to being as nice as mine. just curious... thaqnks for your input fellas. http://cgi.ebay.com/ebaymotors/1971-...QQcmdZViewItem
Old Dec 22, 2005 | 04:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
"nobody wanted to pay near what it's worth", uh ok guy, so part it out, then people will pay more?
That guy isn't a genius, he's very optimistic.
I think you could check out some 2nd gen sites, and ask around there, get a feel for it. Maybe put a $6000 reserve, and start bidding low. If nobody buys it, you can always email the highest bidder and ask what he thinks is reasonable...?
Old Dec 22, 2005 | 04:30 PM
Kross4031's Avatar
Car: 86 IROC
Engine: Pontiac 455
Transmission: TH350
i am on the fence about selling it. it would be a real conversation piece in my 89 camaro i just picked up. i guess i really wanted to know if i had something to brag about. again... thanks for all of your input. i appreciate it.
Old Dec 23, 2005 | 09:31 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Theres a big difference between a 1971 YE 455 HO and the 1970 455. The '71 was a full High Output performance engine with round port heads, cast iron headers, aluminum intake with larger runners, 068 Ram Air camshaft, and a 830 cfm carb. The 197 code heads alone bring about $1500-2000 these days.
The '70 455 is the only high compression 455 made but its more geared toward moving heavy cars around. It a torque monster engine like the Cadillac 472/500 engines. It was sold under 455 HO name in the GTO but its only that in a name. It has a cast iron intake, D-port heads and log style exhaust manifolds. Its comparable to the standard duty '71-76 455 engines had those been high compression.
Its still a good engine and would move a 3500lb 3rd-gen around very quickly. The '70 455 370HP engines are somewhat rare but being they aren't a true HO engine they don't command the big $$$ like '71-72 455 HO and '73-74 SD-455 engines. Your engine is probably worth around $2000. Maybe a little more to the right person.
Your engine is definitely something to brag about, as are all Pontiac engines. Its not a "just another Chebbie" engine!
Old Dec 23, 2005 | 10:40 AM
Kross4031's Avatar
Car: 86 IROC
Engine: Pontiac 455
Transmission: TH350
thanks for the info .. that is good to know
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
