before i click buyit now, tell me if i am wrong
Old Dec 22, 2005 | 07:21 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
due to a sick truck i am going to put heads and a cam in my car instead of doing a ground up rebuild. I am doing what chevy high performance did in "the goodwrench quest".
goodwrench 350
al. heads with 195 runners, 2.02/1.60 valves, .550 springs, 64cc with guideplates.
comp. magnum 224/224 .470/470 or 230/230 .480/.480 opinions?
/\/\/\/\/\/\ idle quality?/\/\/\/\/\/\
comp hyd. lifters
comp. pro magnum roller rockers 1.52
comp magnum double roller chain
cam button and lock plate.
new chromemoly pushrods. i asssume comp cams can tell me the exact length?
Old Dec 22, 2005 | 07:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The magnum lobe profiles are fairly out of date compared to their newer xtreme energy designs and such. On the same note, their Magnum grinds are also fairly out of date compared to their Xtreme Energy grinds.
What cylinder heads exactly?
The only way to know what pushrod length is to dummy it up and get a pushrod length checking tool.
Old Dec 22, 2005 | 07:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I would go with the smaller of the cams, and wait til it's all mocked together to determine correct pushrod length.
Old Dec 22, 2005 | 07:51 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
i have read good things about these on other boardshttp://cgi.ebay.com/ebaymotors/SBC-Strike-Force-Aluminum-Heads-Free-S-H-2-options_W0QQcmdZViewItemQQcategoryZ33617QQitemZ8024254718
or
the aluminium heads from larrys performance from the add in CHP
so what you are trying to say is extreme energy.........
how about e.e. 218/218 .454/.454? or
xe274
i have a bowtie level 2 with 2500 stall
Old Dec 23, 2005 | 12:02 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that's a symmetrical lobe design, 218/218, is that an XE cam? thought they were all asymmetrical....?
I'd highly recommend a lunati voodoo, or a comp xe cam. I think the 274 might be a bit on the large side, 268 would be ok. Just my HO.
Old Dec 23, 2005 | 04:22 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
i looked at the wrong one, you are right. i'm either going with the 274 or 268.
do you think a holley 600 will be enogh or should i get a 670 or 700?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
Linson
Oct 1, 2015 09:50 PM
