stumbles, then runs like a strp-ped ape
Old Dec 23, 2005 | 09:55 PM
jeremys82c10's Avatar
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
Axle/Gears: 8.8 w/3.08's with a trac-lock
if i mash on the gas , part of the time it has a stumble then accelerates way good, it is a carbed car, again, it only stumbles like that part of the time
Old Dec 23, 2005 | 11:36 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
check your carb.
chances are one of two things though others are able to happen
vacuum leak and accelerator pump.
it is prolly one of those two things.
other then that it could be jetting but I almost doubt it if it is a "sometimes" situation.
vacuum leaks are a bitch. they don't effect you sometimes and other times they make the car hardly run.
accelerator pump might just be a little worn also causing intermitent issues with it not sealing right all the time.
Old Dec 24, 2005 | 12:10 AM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
If it is a factory carb, it's a q-jet, the secondary throttle plate could be the problem. It's likely that it's opening late, the fix is rather simple though but it's time consuming. Check out quadra jet tuning tips to get a detailed explanation of tuning. I'd like to help but i haven't had to tune the secondary throttle plates yet.
Old Dec 24, 2005 | 06:36 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
would that really cause it to sumble or just run like it's missing some pep?
Old Dec 24, 2005 | 09:39 AM
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
it is a 3310 holley 750 vacuum secondary carb
Old Dec 24, 2005 | 09:44 AM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
Sounds like either acc pump/cam not set up properly or secondary opening too soon.
What is the rest of your setup? Cam, tq convertor, gears, intake, comp. ratio., timing, etc?
Old Dec 24, 2005 | 09:51 AM
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
i just bought the car but it has a golen crate 350 hp 350 i did some research on it, and if they used the same cam now it is a comp cams xtreme enrgy 268, 3,000 stall convertor, 3.73's, performer rpm intake, 9:1 compression, and the timing i believe is 10 degrees initial, 34 degrees total
Old Dec 24, 2005 | 10:01 AM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
If it were me, I'd play with the pump shooters first. That's pretty easy.
Hard to say if smaller or larger is the way to go. Sometimes you can get some direction by having someone watch the exhaust. If it lets out a cloud of black smoke when it stumbles, then maybe too rich and try smaller on the shooters.
Was it a "tuned" combo including carb?
Old Dec 24, 2005 | 10:06 AM
Car: 90 mustang LX
Engine: 5.0-302
Transmission: t-5
it is tuned to the spec sheet for the motor, but it has sportsman 2 heads instead of the 70cc combustion chamber gm heads it came with
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
