Contole module burnout
Old Dec 26, 2005 | 01:38 PM
bigozzyfan4life's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I have a stock 305 TBI and when I bought the car the guy had replaced the controle module a while back. He said it needed replaced again because it went bad. The car would run good for about 15 minutes and then die and wouldn't start until it cooled down. After I replaced the module it fixed this problem. My question is, what could be causing these modules to go bad so quickly?
Old Dec 26, 2005 | 05:04 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Not enough di-electric grease on the back-side can cause them to overheat and shut down...
Also, I believe Karl (rip) had a problem blowing ICM's a while back and found out his alternator was overcharging and shorting them out...
Old Dec 26, 2005 | 07:09 PM
Vader's Avatar
A failing coil will also eat HEI switching modules. So will turning on the ignition without running the engine for extended periods of time. It doesn't happen as much with electronic ignition as it does with points, but it can.
I'd hate to even try to count how many times I've seen this while people are just listening to the radio with the engine off. That's why there is an ACC position on the ignition switch.
Old Dec 26, 2005 | 10:31 PM
Car: 1992 Camaro RS
Engine: 305 TBI
it's the module on the distributor in case anybody was wondering.
InfernalVortex
Apr 20, 2021 11:31 AM
Thirdgen89GTA
Apr 11, 2016 02:07 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
