Big Problem
Old Dec 27, 2005 | 04:14 PM
formula_k's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 5.0 Liter (305ci)
Big Problem
While working on the formula we left it running for a while to make sure everything was gonna be ok. Me and my buddy went in to eat and came back out and the car was overheating and the coolant was overflowing. Now when I try to start it it just clicks. We charged the battery and tried to jump it. I thought the battery was drained but apparently it's a bit more serious. I'm not sure if some coolant spilled on the starter and messed it up or if there's a head problem. Any help on this would be greatly appreciated!
Old Dec 27, 2005 | 04:30 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
how long did you leave it running for?
check your battery connections that they are good and tight
Old Dec 27, 2005 | 04:59 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
pull the plugs and try turning it by hand. either seized a bearing or hydrolocked the engine. I blue a motor in my first bird racing when I got the motor out #8 was filled with water
Old Dec 30, 2005 | 01:53 PM
formula_k's Avatar
False alarm fellas, it was just an old junk starter. Put a new starter in it and it runs great!
Old Dec 30, 2005 | 02:24 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Thermostat stuck and made it overheat?
Old Dec 31, 2005 | 11:57 AM
formula_k's Avatar
I'm not sure, I can't find what makes it run a little hot. It stays between 1/4 and 1/2 on the temp guage. That's between something and 220 degrees. It almost never goes over 220 though... I'm going to try to flush the radiator and see what happens.
Old Dec 31, 2005 | 01:53 PM
from what I hear that's about the right temp for a 3rd gen.
Old Dec 31, 2005 | 02:30 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
That is normal.
Try getting your radiator cap checked or try a new one.
A bad cap can make you boil over at normal temp.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
