86 2.8L died ??
Old Dec 30, 2005 | 05:55 PM
jak42tn's Avatar
Car: 86 Firebird
Engine: 2.8L
86 2.8L died ??
Been reading the posts for alot of good info,
Problem: My 86 bird ( 2.8 FI - Auto) just stopped while turning around in a parking lot. All idiot lights came on but will not hit.
Checked fuses - all ok
Checked for spark - NONE
Check Engine light - bulb burnt or gone since bought used
Going to take dash apart and replace bulb in CE
IF That will give me the codes on what happened in the parking lot?
Any other ideas?
Old Dec 31, 2005 | 01:51 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
My firebird died when I was going down the highway one day. Once I got it off the road, it would crank but not fire.
It turned out the control module in the distributor went out on me. These cost around $30 at a part store (autozone, etc).
I'm not familiar with the 2.8L, but you may wish to check the distributor.
Hope this helps.
Best of luck!
Old Dec 31, 2005 | 05:58 PM
82knightrider's Avatar
Transmission: TH200C....700R4
check your alt.
Old Jan 1, 2006 | 12:11 PM
jak42tn's Avatar
Car: 86 Firebird
Engine: 2.8L
Thanks for the replies. If it is the distributor module then I should get that code from check engine light, right?
Old Jan 2, 2006 | 09:42 AM
jak42tn's Avatar
Car: 86 Firebird
Engine: 2.8L
It was the distributor module after all. Took it out & had it tested & replaced...It fired right up and is running better than ever. Thanks for the help!
Old Jan 2, 2006 | 01:41 PM
Old Jan 2, 2006 | 02:31 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
someone got lucky!
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
bplessy
Sep 30, 2015 12:14 PM
