White stuff on dipstick???
Old Dec 30, 2005 | 06:39 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Hey guys, about 1500 miles after my last oil change when I pulled out the dipstick to check the oil I find a white streak of stuff on the bottom of the dipstick mixed in the oil. The rest of the oil level reads fine and does not have the white stuff in it. I thought at first maybe it was some coolant mixed in, but my coolant level is perfect and has not changed. Any suggestions on what this might be? I'm going to get the oil changed in a few days anyway.
Old Dec 30, 2005 | 07:04 PM
'86 350's Avatar
Car: '86 Camaro SC
My only guess would be coolant.
Old Dec 30, 2005 | 07:15 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Could it be condesation from the cold weather? I mean, its not a ton, just streaks on the bottom part of the dipstick. The car is running normal, no smoking, only 89K miles, and I'm supposed to be selling it!!!
Old Dec 30, 2005 | 07:21 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
try scraping it off with a towel or something, put the dipstick back in the tube and check it out again in another week or so.
Could be alot of things, but if your coolant level isn't decreasing or your not smoking, then we can rule a possible leak out of the picture.
Old Dec 30, 2005 | 08:56 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Thanks for the replies fellas. I went out tonight and put the dipstick in, wiped it off, and repated this about 5 times and now it comes out without any streaks at all, just good looking oil. I double checked my radiator and it is plum full to the top. I'm pretty sure this is just some sort of condensation from the cold weather cause I'm not loosing anything. I'll check it again in the morning after I drive it. "Knock on wood"
Old Dec 31, 2005 | 08:11 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: White stuff on dipstick???
aren't you old enough to know what that stuff is by now?
Old Dec 31, 2005 | 09:29 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
KCG
Sep 23, 2015 09:05 AM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
