Chevy 3.1L vacuum lines
Old Dec 31, 2005 | 02:11 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
it's not very thirdgen related, but my post contains general tech/engine questions about a motor found in thirdgens. So I can get away with that, right?
I have a 3.1L Beretta as my beater for the winter. I just replaced the fuel injectors (because they leaked and caught fire) and re-routed some vac lines. The MAP sensor's vac line was so horribly cracked that the car ran terrible. Long story short, rather than replacing all of the melted/broken plastic vac lines, I am running the MAP off of the PCV's hose, and the PCV is not hooked up at the moment.
Due to the car not drawing in that extra air through the PCV now, it tends to idle a little bit lower and it's probably running more rich than it should- correct? Am I going to throw off the MAP at all if I put a "splitter" t-fitting in line with the PCV? Do I need any check valves?
And the vac-adjusting fuel pressure regulator runs off of ported vacuum, correct? It looks like it connects to the front of the throttle body.
And finally- the cruise control in the car has never worked since i've owned it. For one the vac line was broken off, and also I'm not positive that it's even electrically connected. What kind of vacuum does that run off of? I'm thinking ported, but I'm not sure.
THANKS GUYS
Old Dec 31, 2005 | 03:16 PM
sellmanb's Avatar
Car: '86 Berlinetta
Do vacuum hoses cost that much? lmao.
I went to my local Schmucks and they just gave me a foot of it free lol.
Best advice - do it right
Old Dec 31, 2005 | 03:27 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
it's not about the cost, it's about having to remove the plenum every time I touch the damn thing. The car cost me $200, and I've put less than $40 into it. It's not really necessary to go that extra mile to make everything OEM.
How have you been, man?
Old Dec 31, 2005 | 04:48 PM
sellmanb's Avatar
Car: '86 Berlinetta
It just seems easier to put fresh lines on it, take off the plenum once, and be done with it
I've been ok, the car sucks though, I snapped the bolt head off that connects my hangers to the carb, so I got a new top piece at the junkyard, and the car wont idle, that combined with a lot of blowby, and a bunch of half finished projects have forced my hand to start selling my 3rd gen parts and eventually the car... getting a '99 VW Jetta -shudders- atleast it'll get me to work and back I guess.
Old Jan 1, 2006 | 12:40 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
keep on rollin though
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
