is this car worth buying?
Old Jan 2, 2006 | 09:41 AM
blalockcreative's Avatar
i may be going to look at this car today...here is what the seller wrote about it:
"i have a 91 camaro rs for sale. its a auto with t-tops. the 305 in it is knocking. the only body damage is a cracked nose and a the passenger corner of the hood is dented other than that its a good body. the interior is ok it could use the seats being recovered and a dash pad being its cracked. the trans shifts good and has a new mount. the front brakes r also new. $800 obo"
im no mechanic, but ive read on here some, that a knocking noise may not necessarily be a rod, but something else like an exhaust leak. i have a limited budget for major mainentance (such as an engine rebuild, etc) and am contemplating if this car is worth buying. what do you guys think??
thanks!
Old Jan 2, 2006 | 01:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
only if you want to replace the motor.
Old Jan 2, 2006 | 02:24 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
You said you're not a mechanic and you have no money. Pass on it.
Old Jan 2, 2006 | 02:27 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
sounds more like third gen project car!
jhawkeye
May 25, 2022 06:33 PM
Streetstuff
Sep 7, 2015 09:23 AM
mustangman65_79
Aug 11, 2015 03:17 PM
hokis
Aug 9, 2015 03:57 PM
MENINBLK
Aug 5, 2015 11:58 PM
