Odometer wont work on cold Mornings
Old Jan 5, 2006 | 07:33 AM
TPIFormula's Avatar
Car: 94 S10 soon to be 305TBI, 01 Blazer
Engine: 4.3 TBI, 4.3 CPI "01 Blazer"
Transmission: 4L60E's
Just like the subject says, On cold mornings here in FL I notice when I go for a drive after the car sat all nite, that the odometer doesnt work until you drive 10 miles or so, The spedo works fine though, any ideas? This will be the 2nd spedo i replaced
Old Jan 5, 2006 | 10:56 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I have the same problem in my 91 RS. It gradually got worse, and now does not work until you drive about 50 - 60 miles or so. Check for codes. I get a code 24 Vehicle Speed Sensor. Picked up a new one, and have yet to install it. I'd bet you thats the problem.
Old Jan 6, 2006 | 05:18 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I have a similar problem- however, the lack of a code 24 and the fact Auto-Xray reads my vehicle speed have indicated to me the problem is not with the speed sensor.
However, the instrument cluster was tested by Luaderdale Speedometer in Ft.Lauderdale, FL. They charged $35 for a bench check plus shipping back to you. I explained that the speedo (BTW, speedo OR odometer do not work) does not start to work until you have driven 10-20 miles, and it seemed worse in cold temps.
So they placed the cluster in the freezer for an hour, then re tested it. It tested fine.
So my problem is somewhere between the sensor and cluster.
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
kyle5647
Aug 15, 2015 11:56 PM
apie2546
Aug 10, 2015 05:43 PM
kyle5647
Aug 7, 2015 03:08 PM
