Loads of trouble, im sure someone can help me :-)
Old Jan 5, 2006 | 05:18 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Hey guys....I have looked just thinking maybe one of you might have found something alot cheaper than what I have seen. I'm looking for a 1991 z28 350 engine rebuilt kit including pistons. I've found some but they're running at $350 as far as i looked, maybe one of you have bought them somewhere else for a cheaper? I'am a student at the time, so my budget isn't so high but I have some cash saved up, just not $350. Thanks I appreaciate it
Old Jan 5, 2006 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you can't spend more than $350, I'm having trouble imagining how you are going to afford the machining work. If you can't afford the machining work, why do you need pistons?
Guess it comes down to this: What problem are you trying to fix?
Old Jan 5, 2006 | 06:44 PM
Car: 1991 camaro RS
Machine work? I don't need machine work on the block, I already got it de-glazed and hot tanked, all I need are some gaskets and the pistons, the pistons I already have but since im rebuilding the whole thing, I'd just want to be safe and buy new ones. I don't know what your talking about
Old Jan 6, 2006 | 04:55 AM
yzinger1's Avatar
Car: 1991 transam,gunmetal,t-tops,
Engine: 305,.030,k&n,airfoil,3inch exhaust,flowmaster80
Transmission: 700 r4
Axle/Gears: 4:10 posi unit
rebuild kit
go to www.northernautoparts.com look at their prices .i think you will be pleasantly surprised ,jimmy
Old Jan 6, 2006 | 12:33 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
maybe im slow... but if you get new pistons dont you have to get bored to the new piston sizes?????
Old Jan 7, 2006 | 10:08 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
not if you keep the same bore size....if the cylinders are in good shape , no need for boring.
Old Jan 7, 2006 | 06:01 PM
five7kid's Avatar
And no need for pistons. That was my point.
Why do you think you need to replace the pistons?
Old Jan 7, 2006 | 06:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'm with 5-7 on this. What exactly is it you are tring to fix to begin with? Considing what a rebuild kit comes with (bearings, gaskets, rings, sometimes pistons...). If you are getting it because of the bearings, the crank will need turning, etc. If you're getting it for the pistons, what's wrong with the current ones? Re-ring kits do exist....
Old Jan 7, 2006 | 07:38 PM
Car: 1991 camaro RS
There is nothing wrong with the engine. I see what you guys are trying to say...The reason why I'm getting a rebuild kit, is because I just got this engine off a friend, works fine I just wanted to rebuild it now that its out of the car, and I won't have any troubles with it soon (hopefully) It's been hot tanked and de-glazed the crank is fine (machine shop mententioned). About the re-build kit. I already found one for 250 comes with pistons gaskets lifters cam etc. So thanks for all the PM's with the web address (really helped)
Old Jan 7, 2006 | 09:50 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Man, I gotta wonder about the quality of a rb kit with pistons
for $250.....I think I'd stick with what You've got.....maybe a
re-ring kit with bearings and gaskets....come see me in Tucson,
I sell Sealed Power kits.....
Attached Thumbnails Loads of trouble, im sure someone can help me :-)-marc2.jpg
Old Jan 7, 2006 | 10:41 PM
Car: 1991 camaro RS
Looks like a good kit to me? Comes with flat top pistons with a 10:1 compression ratio
Old Jan 7, 2006 | 11:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Got a link to this kit? Also, keep in mind, new slugs means new balancing job more than likely.
Old Jan 7, 2006 | 11:37 PM
five7kid's Avatar
And machine shop labor to hang them on the rods.
Old Jan 8, 2006 | 01:48 AM
Car: 1991 camaro RS
Yeah, Check it out http://cgi.ebay.com/ebaymotors/ws/eB...tem=7989504515
P.S No machine work needed, cylinder walls looks great, 5 is right though, I need to get the connecting rods off my old pistons and slip them into the new ones.
Old Jan 8, 2006 | 09:37 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Maybe so...but you really should re balance the bottom end if your hanging new pistons AND you'll have the added charge of hanging a set of pistons on your rods. For that price I don't see the weight of those pistons being very uniform. I would stick with the origionals, assuming they aren't damaged. My $0.02
Old Jan 8, 2006 | 10:53 AM
five7kid's Avatar
Get a rering kit with rings, bearings, and gaskets, and leave it at that.
You seem convinced that pistons are a must, when in fact they are not unless you've done something to the ones that came out of the 350. If they need replacement due to wear, then you can be sure that the block is not "great".
I really don't understand your fixation on getting new pistons.
Old Jan 8, 2006 | 03:47 PM
Car: 1991 camaro RS
LOL, I'm not really determined to get new pistons. I'm more for the rings gaskets etc. Besides how much less would it be to get a smaller kit without pistons? I don't think It could be to much of a difference might as well get the one that comes with the new pistons.
Old Jan 8, 2006 | 05:15 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
That depends on the quality of the kit. You can get a decent kit w/o pistons for the same cost of a cheap kit w/pistons...problem is, the pistons probably suck and will more than likely be very weak. If the current pstins are good, stay with them. If you really want new pistons, go for a decent set.
Anyone know if the Summit branded pistons are any good? Most of the summit stuff is pretty inexpensive.
Old Jan 8, 2006 | 05:58 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
This is all you need
$95 and you cant beat summits shipping
Old Jan 9, 2006 | 05:39 PM
five7kid's Avatar
That kit is for earlier style blocks, but that's the idea.
Old Jan 9, 2006 | 05:44 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Sorry mr. Kid. I didnt pay attention. If you really want some piston check Scoggin Dickey. I think they have some Silv-O-Lite cast for like $7.50 a piece. I dont know the quality though. Someone else can chime in on these.
$7.50 Silv-O-Lite Pistons
Old Jan 9, 2006 | 07:09 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
So cheap I may buy one or two to make a fun project out of!
Old Jan 10, 2006 | 05:06 PM
Car: 1991 camaro RS
Thanks for all the Input guys
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jrdturbo
Mar 31, 2016 02:58 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
efiguy
Sep 27, 2015 01:30 PM
