Anyone with desktop dyno?
Old Jan 9, 2006 | 05:30 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Was wondering if anyone could entertain my curiosity in desktop dyno and try out my setup? Would be much appreciated
My setup:
L98 350 stock bottom end
9.3:1 CR (64cc L98 heads)
Heads have bowl work and port work.
Stock valves (190s and 150s I think?)
Cam is ZZ4 w/ 1.5ratio exhaust and 1.6intake making the specs:
Duration @ 0.050" Lift: 208/221
Lift: .505"/.510"
Lobe Separation: 112
Intake is ported TPI base, SLP runners and matched ported plenum, stock TB w/ airfoil. AFPR @ 50psi w/ 22lb inj
Let me know if you need any other info.
Thanks for your time.
Matt
Old Jan 9, 2006 | 08:11 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
25-30 more than stock, depending on the extensiveness of the work done.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
